Re: Farmall B with welded crack in block
Posted by gene bender on September 02, 2010 at 05:21:44 from (67.55.227.196):
In Reply to: Farmall B with welded crack in block posted by sflem849 on September 01, 2010 at 20:02:36:
I fixed one yrs ago ground it smooth and put some rubber cement that they use holding your windsheild. Its been several yrs and will not leak. Tractor has been on several 180mi tractor rides. You can also use JB it works also some fiberglass will also work as we are just talking a weep correct. Mine had been welded but water fan out as fast as you could pour. Grind it clean is important.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
