Re: Super C rebuild
Posted by gene bender on September 02, 2010 at 05:27:26 from (67.55.227.196):
In Reply to: Super C rebuild posted by Alex in Windsorville. CT on September 01, 2010 at 18:37:29:
Remove the enging and put on a stand so you can remove the crank then take it to a shop and let them mike it out. Remove a sleeve so you can get the measurements from the old sleeve the width at the bottom where the rubber seal fits is important so you can get the correct replacement sleeve and piston set. Rings,sleeves,rod bearings,main bearings and complete gasket will cost around 375.
