Re: 1976 Loadstar 5-speed question
Posted by Bob M on September 02, 2010 at 06:00:38 from (74.42.43.234):
In Reply to: 1976 Loadstar 5-speed question posted by Jack Deere on September 01, 2010 at 21:51:33:
The main advantage of the 2 speed axle is somewhat better acceleration.
Using the 2 speed "splits" each of the 5 main gears. This gives 10 (or sometimes just 9) more closely spaced gears. If the 5 + 2 are shifted properly it keeps the engine RPMs close to its power sweet spot in each gear. End result is a somehwat quicker acceleration.
However for a farm truck the straight 5 speed should work fine for you - you'll just be a bit slower getting up to cruising speed.
