Re: Re: Re: Cub overhaul of one cylinder?
Posted by ltf in nc on June 13, 2000 at 19:57:18 from (206.228.215.183):
In Reply to: Re: Re: Cub overhaul of one cylinder? posted by p on June 13, 2000 at 16:15:02:
This is an acceptable solution and should extend the life of the tractor for quite some time if it is not used in an extensive farming/nursery operation. I suggest that the engine be torn down to do an inframe overhaul and then start posting you findings or questions. Members of this forum will assist in overcoming any problems you encounter. If you elect to do this, prior to the teardown you will need to do some fact finding. Buy a cheap compresssion gauge and test each cylinder, then pump a few shots of oil in each cylinder and repeat the compression test. What is the oil pressure at idle when the tractor is at its hottest? Record all findings. Let us know you decision.
Post A Followup
: Re: Re: Re: Re: Cub overhaul of one cylinder?
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
