Re: International 330U won't start
Posted by El Toro on September 02, 2010 at 13:27:15 from (74.103.74.58):
In Reply to: International 330U won't start posted by Brad65 on September 02, 2010 at 12:32:00:
It may be your solenoid. Set the brakes and make sure the tractor is out of gear and then short across the solenoid terminals using a screwdriver. With your ignition switch in the on position the engine should start when you do that. Hal
