like others have said, it"s a lot easier to fix the flat while it"s on the tractor. i"d borrow/buy a bead breaker, at least 2, preferably 3 tire irons, and a 3-4 # hammer. then you"re set to handle any tire.
if you really want to take it to someone- i would leave the cast center right on the axle, and take the rim off of that. i think it"s something like 12 bolts, nuts, and clamps that hold the double bevel rim to the cast center. pop them off and you"ve only got the weight of the rim and tire, not all that cast to manhandle.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
