If you have a multimeter, set it to read 12 Volts DC and measure the voltage between the Ign. Switch side of the coil and ground (tractor frame.
When the switch is turned to "Start", if you read zero Volts, you likely have a broken wire between the Ign. switch "Start" terminal that goes to both the starter solenoid and direct to the switch side of the coil (after the ballast resistor). That extra coil wire is used on many ignition systems to put the full battery voltage to the coil only when starting (If yours was wired that way). Then when the switch is released from "Start", the coil gets its voltage through the ballast resistor from the "Run" terminal on the ignition switch.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
