Re: What to do when you cant get your rim off the axle????
Posted by Randy in NE on September 03, 2010 at 04:17:15 from (204.124.192.31):
In Reply to: What to do when you cant get your rim off the axle???? posted by Ron in Mississippi on September 02, 2010 at 15:52:13:
You might be farther ahead to bite the bullet and hire it done. I had to take the tire off of my Case 300 (28" tires). My brother has tire tools for fixing truck tires. We beat on it for half an hour with an 8 lb sledge. Finally gave up and paid to get it off. He spent about an hour with his air tools. Calcium chloride does nasty things to a wheel.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
