Re: 300 wont start till I the starter stops
Posted by rustyfarmall on September 03, 2010 at 04:49:13 from (209.152.78.140):
In Reply to: 300 wont start till I the starter stops posted by PaulGinMn on September 02, 2010 at 17:27:27:
You need to wire in a secondary ignition circuit that will provide a full 12 volts to the ignition coil while the starter is running, and then have that circuit disabled after the engine starts. It needs to be in addition to the wire that feeds current to the coil through the ballast resistor.
