Re: 300 wont start till I the starter stops
Posted by rtb321 on September 03, 2010 at 05:01:25 from (69.207.67.77):
In Reply to: 300 wont start till I the starter stops posted by PaulGinMn on September 02, 2010 at 17:27:27:
[Since it has been converted from 6 volts, most likely it had a resistor added before the coil to continue to use the original coil. At best you are going to see about half of cranking voltage at the coil. Cranking voltage may be down around 10 volts.[/quote]
Either way voltage at the coil in run position and no voltage when cranking = bad key switch
