Re: 300 wont start till I the starter stops
Posted by mkirsch on September 03, 2010 at 05:53:20 from (64.80.108.57):
In Reply to: 300 wont start till I the starter stops posted by PaulGinMn on September 02, 2010 at 17:27:27:
Where did he say no voltage to the coil while cranking?
Cranking takes a lot of energy, and really draws the battery voltage down while it's happening. 9-10 volts on a 12V converted tractor is typical.
The ballast resistor essentially cuts the voltage in half, so the coil is only seeing around 5 Volts during cranking. Not enough for a hot spark.
Dad's Super M does this too. It's pretty typical.
