Re: What to do when you cant get your rim off the axle????
Posted by mkirsch on September 03, 2010 at 06:02:12 from (64.80.108.57):
In Reply to: What to do when you cant get your rim off the axle???? posted by Ron in Mississippi on September 02, 2010 at 15:52:13:
What are you going to do with the wheel once you get it off???
You've said multiple times that you have no way to break the bead.
What good will having the wheel off the tractor do?
Do you have a way to handle it safely?
BTW, if you've got a 48" farm jack and a log chain, you can break the bead easily. Jack directly against the drawbar to break the inner bead. Chain the jack to the drawbar to break the outer bead.
