Owen's suggestion below, to put a 4 terminal starter relay in place of a 3 terminal design is good. and cheap. Run all wires as they were, but add a 12ga wire from the "I" terminal on the relay to the side of the coil not connected to the distributor. Adding heavier (0gauge) battery cables will also help. Doing a battery load test is also a good choice, as a bad cell will still crank well, but be low in ignition voltage. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
