Re: Farmall C clutch chatter- Rear main seal?
Posted by ScottyHOMEy on September 03, 2010 at 14:28:09 from (71.241.195.119):
In Reply to: Re: Farmall C clutch chatter- Rear main seal? posted by challenger on September 03, 2010 at 13:47:37:
The "float" of either the carrier or base for the graphite bearing is a factor. There is a lot of intentional imprecision designed into the way they fit into the fork -- allowing the faces to align with the plane made by the tops of the fingers in the instant before the real pressure comes on. There is enough slop there that either should align okay if in good condition. Trick is (at least in the A/B/C) that there's a cotter pin in the middle of the tapered dowel that the fork hinges on. Positioned such as to prevent the dowel from sliding out too far either side of the torque tube casting, it still allows the carrier to slide back and forth .
I'm not really sold on the axial vs. thrust bearing idea. Thrust-type steel throwout bearings were hardly a new concept by the late 40's. While history may lead us to doubt the business acumen of IH's management, their engineers were first rate. They'd have specced the proper type of bearing.
As for wear in the graphite vs. steel, I come out in favor of less wear on the steel. Within the range that either will float, the gyroscopic effect (I know, there's another, proper, name for it, but it escapes me) of the center of the bearing turning will cause it to center itself up as it picks up speed -- it will shift as much as the carrier allows to center and spin-balance itself. And if it is off center, the fingers of the clutch are not as apt to rip or chip away at the steel face as they would on a graphite face.
Again, not expertise, but general thoughts.
