Re: 300 wont start till I the starter stops
Posted by Ohiohillbilly on September 03, 2010 at 17:33:37 from (69.99.213.206):
In Reply to: 300 wont start till I the starter stops posted by PaulGinMn on September 02, 2010 at 17:27:27:
The ballast resistor puts off a fair amount of heat. If you have a coil with an internal resistor all this heat is absorbed into the coil. Also with the resistor and the bypass circuit you will have a hotter spark on startup than with a internal resistor coil.
