Re: Farmall C clutch chatter- Rear main seal?
Posted by Bill in NJ on September 03, 2010 at 18:26:58 from (4.248.92.94):
In Reply to: Re: Farmall C clutch chatter- Rear main seal? posted by Faster346 on September 03, 2010 at 12:27:59:
Whether you replace your clutch or not would seem like a personal preference thing. If you can live with the chatter, then leave it be. I can tell you that the chatter probably will not go away by itself. If you want to get rid of the chatter you have to get in there and see what the cause is. It might not be very evident. In my previous post I mentioned I had to get an after market carrier. I overlooked telling you we are replacing the graphite bearing with a ball bearing type throw-out bearing. The fingers not being adjusted correctly will cause chatter with both of the types of bearings. I also thought of another cause for the chatter. A broken or weak spring(s) on the pressure plate could also be a cause. It's a little tricky splitting the tractor. You need to support both the back and front halves to split it. The rear half is easy, what with the two wide spread rear wheels. But the front half is another story. It wants to tip over if you don't have a wide spread support mechanism. Good luck no matter which path you take.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
