No need to fight those wedges to take the cast wheel off the axle . Jack under the axle housing lifting tire just clear of ground . Loosen twelve bolts and rim clamps. Remove eight of them leaving four of them at the top. Carefully let jack down a little until the four remaining clamps no longer touch rim . Remove them and jack the axle up a little and work the rim and tire away from the cast center. Ive done many that way by myself . Be advised that when you reinstall the twelve clamps and bolts that two of them are different from the other ten. These two are to be located on rim drive lugs (the "bumps" on the bevels) at 90 degrees from each other. Tighten them first. If rim clamps are not installed properly the rim will not be mounted straight with the cast wheel . Wheel/tire will likely wobble noticeably at road speeds. Have an operator's manual ? Tells how to do it I can send you pages from manual if you like .
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
