Re: amp meter wiring farmall cub 6 volt , with cut out re...
Posted by John T on September 03, 2010 at 20:24:06 from (66.244.97.31):
In Reply to: amp meter wiring farmall cub 6 volt , with cut out regulator posted by ejensen on September 03, 2010 at 19:37:39:
Hot voltage feeds to loads like lights should be on the same side of the ammeter (I call the load side) as the wire that goes down to the cutout relay. Theres usually only one wire on the ammeters other (I call supply side) terminal which leads to the hot ungrounded battery post often via a wire to the starter post where the big battery cable attaches.
Battery on one side,,,,,,Cutout (to genny) and loads (Lights and Ignition etc) all on the other ammeter side.
That way the ammeter accurately registers current into (charging) or out of (discharging) the battery
John T
