Re: Super C won't crank
Posted by rustyfarmall on September 04, 2010 at 12:53:43 from (209.152.78.140):
In Reply to: Super C won't crank posted by teddy52food on September 04, 2010 at 10:28:32:
It is also possible that the starter drive has become jammed in the teeth of the ring gear on the flywheel, which is a more or less common occurence. Get your wrench and loosen the bolts that hold the starter on. Loosen the bolts enough that you can pull the starter out a little way. If the drive was jammed, you will hear, as well as feel, a "click" when the drive becomes un-jammed. Shove the starter back and tighten up the bolts and you're good to go. The same thing might happen again tomorrow, next week, next month, or maybe never again.
