Re: Smoke from the bell housing on W6
Posted by Bob M on September 04, 2010 at 18:29:43 from (67.240.162.65):
In Reply to: Smoke from the bell housing on W6 posted by mkirsch on September 04, 2010 at 15:58:08:
I'm with PUTTER - sounds like old mouse nest, chipmunk's winter seed stash or similar is burning from friction against the flywheel/clutch.
No way I know exhaust can leak into the bellhousing on a W6...
