Re: What to do when you cant get your rim off the axle????
Posted by RPM1941 on September 04, 2010 at 19:58:17 from (173.25.70.110):
In Reply to: What to do when you cant get your rim off the axle???? posted by Ron in Mississippi on September 02, 2010 at 15:52:13:
The wheel hub is called Wedge-lok if you have a single 12pt cap screw per wheel parallel to axle, the heavy u-plates were the tools sent by IH to push or pull the wedges, I used to set up new tractors & if I recall they sent 2 u-plates, 2 long bolts, 2 spacers, with the new tractor, 1 12pt short socket wrench, 1 3-4' cheater pipe, trick was gettings them loose without damaging wheel hub, wedges, 1 wedge has 12pt bolt welded in, heating the hub was ok, scorched the paint tho, sometimes wedges were so tight we blew them out with cutting torch, then getting them back tight & staying tight was next, hammering with sledge was ok but not end of axle, end thrust would crack Timken inner axle bearings. It was HD according to IH but SOB in field for service.
