Posted by Jay Snyder on September 05, 2010 at 09:43:21 from (71.87.118.248):
In Reply to: Gray Smoke? posted by smokeingten on September 02, 2010 at 22:22:22:
My guess is that if you are getting a little water down in the cylinders or atleast a couple. Same as the water injection on our pulling tractors. At lower rpms and lack of heat it will make the exhaust gray and then clear out but that is a timed thing in our tractors. If you go to a tractor pull with super farms or prostocks you will see this also as they bring the rpms up in them. In their case it should go white to gray to flame(also known as the cone) to black. the white in their case is just unused fuel. Do a pressure check on the cooling system and make sure that everything is seated exspecially if you have been inside of it. Also if you have been inside of it was it broke in correctly? May be a head gasket didnt seat right and is losing alittle water down in the cylinders. I suppose you could also have a fouling injector and it is not putting out the correct amount of fuel at the lower rpms and leaning out a cylinder changing the smoke color. I would check for water in the cylinders and go from there. I would most defently try to figure out what it is because it could become a larger problem later on. If it is water it will sooner or later push wherever it is leaking all the way out of it. If it is fuel it could burn piston or wreck the valves and hurt the motor badly. If you got anymore questions let us know. Goodluck Jay
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
