Re: field terminal wiring on a 1948 IH cub tractor
Posted by ejensen on September 05, 2010 at 12:43:42 from (67.170.86.34):
In Reply to: Re: field terminal wiring on a 1948 IH cub tractor posted by John T on September 05, 2010 at 09:22:57:
John,
Thank you for the information.
Chris
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
