Posted by John T on September 05, 2010 at 13:12:00 from (66.244.97.31):
In Reply to: battery starting trouble posted by caryfarmall49 on September 05, 2010 at 11:49:58:
Its pretty fast n easy n usually free to do A LOAD TEST on that battery which is whats really needed. In the event it tests okay Id remove, clean n wire brush, n re atatch each n evey battery n ground n starter n switch connection and insure the ground is to a good solid frame member NOT any thin wimpy rusty sheet metal. It depends on the charger but a slow low amp charge using a 12 volt charger could work just keep an eye on it to avoid overcharging i.e. too much bubbling and outgassing and/or excess current draw. Of course (if the battery is okay???), the starter itself or the switch may be at fault but Id try the above first ESPECIALLY the battery load test
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
