Re: Hauling Farmall B
Posted by Haas on September 06, 2010 at 06:39:36 from (75.204.140.222):
In Reply to: Re: Hauling Farmall B posted by ScottyHOMEy on September 04, 2010 at 19:18:07:
Yes, the rating is reduced when pulling at an angle and they do need to be fully threaded. If you get the lifting rated kind, they will be threaded. The guy at the fastener store gave me some info on the ratings for straight pull and also at an angle (I don't recall the angle). As I recall, the 3/4 inch was 6000 lbs or so on a straight pull and maybe half that on an angle. Info on this should be published somewhere, but I have not looked. Those are working loads, so that is plenty to use 2 inch wide load straps. I mostly use these on smaller tractors and the B would fall into that category.
