Re: Timing
Posted by Janicholson on September 06, 2010 at 09:19:30 from (199.17.6.223):
In Reply to: Timing posted by farmall706 on September 05, 2010 at 22:24:45:
It has centrifugal advance. Going from idle or slower advance of Zero, to max advance at rated RPM. If the advance weights and springs are working as designed it is OK. With a timing light, and an degree tape on the pulley, it is possible to make sure this is good. A simple test to assure it is working at all is to gently turn the rotor in the direction of rotation by hand if it turns a few degrees and then will snap back to rest it is likely working. Weak springs are not tested this way. Jim
