Re: 450 Pump O-Rings
Posted by MeanGene1 on September 06, 2010 at 09:37:55 from (209.148.104.194):
In Reply to: Re: 450 Pump O-Rings posted by Janicholson on September 06, 2010 at 09:25:39:
Thanks, Jim, makes sense as they don't seem to protrude below the surface as much as they should to seal correctly. As the ones that came out are identical to the plain 'ol generic rings in my kit, seems like someone installed incorrect "standard" rings in the past, now I know for sure what needs to be done.
Thanks again for sharing your knowledge and experience, saved me a lot of running around & "looking up"
