Re: Is there a trick for fixing a woobling 400 clutch pedal
Posted by Janicholson on September 06, 2010 at 11:26:36 from (199.17.6.223):
In Reply to: Is there a trick for fixing a woobling 400 clutch pedal posted by John Seasly on September 06, 2010 at 11:18:43:
Repair isputting a bushing where there was none.
The shaft if worn more than .003" will need to be turned down and polished to remove the wear, then the bushing fit to the shaft with .001-.112 clearance. Drill a hole for grease to enter the bushing. Jim
