Re: Timing
Posted by Jim Becker on September 06, 2010 at 19:46:57 from (173.57.154.186):
In Reply to: Timing posted by farmall706 on September 05, 2010 at 22:24:45:
Just static time it at 0 degrees. At low idle (400 rpm) it should still be at or near 0 degrees. My reference says 22 degrees at high idle (2530). All you have to do at high idle is put the light on and check for full advance.
You are aware that running an engine at high idle is far from running it wide open aren't you?
