Painting a Tractor Part by Part
Posted by Tom in Iowa City on September 07, 2010 at 02:36:32 from (173.29.204.53):
I am restoring a McCormick-Deering 22-36.
I will be having the main frame sand blasted, primed with PPG epoxy primer and then coated, all by a professional painter.
THEN, as I ready each part, front axle, steering connection, steering knuckles, etc., THIS WILL TAKE TIME AND BE DONE OVER ABOUT ONE YEAR'S TIME.
I want to sandblast each part, prime each part and paint each cast part with a brush.
I want to use a paint WITHOUT HARDENER, to avoid health hazards with isos.
I think my best choice is an ACRYLIC ENAMEL.
Can you verify that this is a good choice for a paint which will not REQUIRE a hardener?
The tractor will always be kept inside.
Is there a DuPont or PPG acrylic enamel line?
Tom
