Re: battery starting trouble
Posted by rustyfarmall on September 07, 2010 at 09:26:48 from (209.152.78.140):
In Reply to: battery starting trouble posted by caryfarmall49 on September 07, 2010 at 08:51:16:
If the original 6 volt generator is in good condition and functioning, then go back to a 6 volt battery. Use minimum of #1 gauge battery cables, and make sure all connections are bright and tight.
If the generator is not functioning and cannot be made to function with new brushses, etc., then it will be less costly to convert to a 12 volt, alternator system.
