Posted by dpski on September 07, 2010 at 09:36:35 from (128.222.37.57):
Working my way through the SC and notice the u-joints for the steering are real worn and loose. It looks like the front one is serviceable such that the spider can be replaced, is that true? Can you still get those parts?
The rear u-joint near the bell housing is a different story. U-joint doesn"t look serviceable at all and it"s welded onto the horizontal shaft coming from the front u-joint. I"ve found replacement u-joints shown in the picture above, although not specifically called out for use on a SC, but rather for H, M, Super M, 300, 350, 400, 450, 7/8" shaft diameter matches. But it appears I would have to have the old one cut-off and the new one cut and welded on in same location. Is this the only way to fix these?
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
