Posted by old on September 07, 2010 at 09:53:03 from (4.245.6.40):
In Reply to: Re: Fuel flow problem. posted by ste_fano on September 07, 2010 at 09:30:04:
LOL yep it is working just as it should if the float needle is sit closed. That sediment bowl is full of air and well lets just say air and gas can not fill the same spot at the same time so yep it will not fill till you start the engine and when the float drops to open the needle the sediment bowl will then fill with gas. If it did not do as it is then you would have a leak in the fuel system which would not be good
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
