Re: Rebuilding gear teeth by welding
Posted by CenTex Farmall on September 07, 2010 at 14:28:09 from (32.176.116.208):
In Reply to: Re: Rebuilding gear teeth by welding posted by 1968 403 on September 07, 2010 at 14:21:51:
Well, really I just want to repair this myself to see if I can do it. The transmission and the tractor as a whole is pretty well worn and I'm not too worried about it. I'm going to put the loader on it and use it as a chore tractor. If it were more critical I would simply replace it with another input shaft. I appreciate the thought however.
However I end up fixing it I'll share the results right here.
