Re: Cub overhaul of one cylinder?
Posted by Greg Martin on June 14, 2000 at 17:04:42 from (216.128.162.191):
In Reply to: Cub overhaul of one cylinder? posted by brian on June 13, 2000 at 12:26:42:
I've done this several times, pull the plugs, find the fouled one, pull the pan and head, use a putty knife to remove the head, the gasket is a sandwich type gasket[ 3 pieces] pull the piston, the rings will probally be stuck to the piston,[ you should be able to look at the cylinder and see where the rings are collapsed by the wear on the cyl] ,go to a real auto\ truck supply, get a set of rings for 1 cyl, a tube of RTV sealer[ red or black] and a can of wheel bearing grease.. Remove the rings, break one of the old rings use it to remove all the carbon in the piston[ scrape till u see aluminum.. Stagger the ring gaps oil and install,, If the rod bearing is down to brass, I would replace all the rod brngs [4] with .003 oversize bearings.. Remove the lower plate of the oil pump, sand it on a flat surface and put a 1\4" nut in the bypass spring to add a little pump pressure.. I expect to hear some flack on this repair, but have been broke before but I was still riding. I did this on a 58 ford pu and drove it for 3 yrs. How about it ITF, got any thing to add?? Forgot about the head gasket., coat both sides with the grease, do not scrape the head or block, retorqe to specs with a grunt, run 2-3 hrs retorque....
Home
| Forums
Today's Featured Article -
Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
