Re: Fuel flow problem.
Posted by Tyler Jackson on September 07, 2010 at 16:24:38 from (75.207.252.50):
In Reply to: Re: Fuel flow problem. posted by rustyfarmall on September 07, 2010 at 09:20:57:
I don't know about 300s but on mine it did the same thing and all i had to do is turn on the bleed valve on the carb and let the air out of the bowl and line. it shot right out when i turned the bleed valve
