Posted by El Toro on September 07, 2010 at 17:25:25 from (74.103.74.58):
In Reply to: Re: Distributor work posted by David A.. Smith on September 07, 2010 at 17:10:27:
You remove No1 sparkplug near the radiator then hold your thumb over the plug hole while a helper hand cranks the engine until you feel pressure. I would drop a long plastic straw on top of the piston then have the helper to keep slowly hand cranking the engine while you watch the straw rise. When it quits rising your No1 piston should be TDC on the compression stroke.
Rotate your rotor so its pointing to the No1 plug tower on the cap which is around 1 o'clock and install the distributor. Hal
Today's Featured Article - Trailering Your Tractor - by Curtis Von Fange. One of the fun things of summer and fall are the parades and tractor shows that go on across America. Many owners of tractors travel long distances to attend these shows and they usually take their restored iron along with them. Safe trailering practices and inspections will ensure that the event is a fun one. A good habit to develop when using a trailer is to give that ‘quick look over’ before taking it on a trip. Before hooking up to it check the tongue for proper operation. The latche
... [Read Article]
Latest Ad:
[More Ads]
