Re: Rebuilding gear teeth by welding
Posted by soybeanjoe on September 07, 2010 at 17:31:37 from (66.213.171.108):
In Reply to: Rebuilding gear teeth by welding posted by CenTex Farmall on September 07, 2010 at 14:02:47:
Years ago Dad put made anew tooth on a gear off a baler using baling wire & a actylene torch. Guy that he made it for said the tooth was still in good shape several years later when he traded the baler off.
I don't have 10% of Dad's welding talent so if it was me I'd take the gear o a machine shop. If you don't do it right you could end up having to replace more than just that gear. I don't mind trying things I don't know as long as it's not going to cost me anymore than the damage already done.
