Re: Distributor work
Posted by Janicholson on September 07, 2010 at 17:35:44 from (67.72.98.45):
In Reply to: Re: Distributor work posted by David A.. Smith on September 07, 2010 at 17:10:27:
There is no issue with oil in any of those housings.
As mentioned, if it ran when shut off, it is just important to get it together the exact same way.
The rotor should be used to mark a point on the housing where it is pointed now. The location of the distributor housing on the extension housing should be marked with a chisel across the metal to assure an alignment. If it is reinstalled in that configuration, it will be OK.
A coil mounts to the top of the extension on the bolt shown.
a wire from the positive terminal on the coil connects to the distributor side terminal. (assumes positive ground 6v as from the factory)
a wire from the neg terminal on the coil goes directly to the ignition switch in the elect box.
There are many photos in the gallery. There are no issues with the generator fitting where it belongs. We do not know what year or specific model it is so describing the charging system needs to wait until we are informed. Jim
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
