Re: Rebuilding gear teeth by welding
Posted by Janicholson on September 07, 2010 at 17:52:45 from (67.72.98.45):
In Reply to: Rebuilding gear teeth by welding posted by CenTex Farmall on September 07, 2010 at 14:02:47:
If you take it out to weld it (the only way to even consider the job without getting spatter on other gears and destroying things then getting grinding dust into everything) then putting a good gear into the trans is 3000 times more likely to be satisfactory. It is done only when a gear is irreplaceable, and then by a machine shop with profile grinding tools and heat treatment. casehardening ovens. Even a beater tractor deserves parts that make it serviceable and avoid the haul to China. Jim
