Re: need 806 Voltage Regulator
Posted by pete 23 on September 08, 2010 at 10:16:09 from (173.87.16.222):
In Reply to: need 806 Voltage Regulator posted by KrisM on September 07, 2010 at 18:04:31:
The rubber mounting base came seperate on service regulators, so we normally used the original mount. Took a little dinkering around with new bolts instead of rivets if I remember correctly. It was a three unit regulator and did a good job compared to the two unit.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
