Re: Super C still won't crank
Posted by El Toro on September 08, 2010 at 13:26:03 from (74.103.74.58):
In Reply to: Super C still won't crank posted by scarlson on September 08, 2010 at 10:49:21:
Are you sure battery voltage is reaching the starter when you pull the handle to start the engine. Have you tried shorting across the studs on the starter with a screwdriver to see if the engine will crank. Make sure the tractor is out of gear and the brakes locked when doing this. Hal
