Posted by Brownie 450 on September 08, 2010 at 15:41:59 from (66.43.241.180):
In Reply to: 1640 final drive posted by msb on September 08, 2010 at 14:30:16:
Have you tried Hines Equipment Repair---Delta, Ohio? If you run out of contacts in your area, try Franzen tractor parts---563 673 6631. Monmouth, Iowa. They have lots of IH combines to part out.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
