did you use a 6 volt battery? If you tried to cheat and use a 12 volt you probably burned out the coil, and maybe some other things. Or if you were using 6 volt, might be condenser, check for juice getting to the distributer, before you take it off. sometimes the resistor up under the dash will burn out. could also be a bad connection in the ignition switch, flick it on and off a few times.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
