Re: Super C still won't crank
Posted by Janicholson on September 08, 2010 at 18:57:45 from (64.61.211.228):
In Reply to: Re: Super C still won't crank posted by scarlson on September 08, 2010 at 14:51:09:
I cannot see your SC. Many have a mechanical switch that is mounted on the starter with 2 screws.
THe mounting position of the switch is away from the contact (under the sw) filing out the holes will allow the switch to move toward the contact, allowing it to make contact. If your tractor has a different type switch, let us know. (or use a picture). A direct hump from battery to starter stud, and battery to ground, will bypass all switches and determine if the starter is working.
Make sure it is in neutral. Jim
