Re: F-30 Radiator Fix
Posted by rustred on September 08, 2010 at 22:16:34 from (74.198.148.43):
In Reply to: F-30 Radiator Fix posted by Chris Settles on September 08, 2010 at 20:28:05:
do it yourself. that is the simplest rad to work on. just unbolt the top and lower tanks and then you can clean the cores with a rod use a pressure washer and air and do what it takes to clean them. then make yourself the gaskets and bolt it back together.and if the core is rotten you can replace it with a new one and bolt it back together. nothing hard here.
