Posted by mkirsch on September 09, 2010 at 05:39:15 from (64.80.108.57):
In Reply to: stuck in da MUD!!! posted by mike paulson on September 08, 2010 at 17:05:36:
I don't see anyone explaining the basic concept of chaining to the wheels...
In one method, you are essentially driving ON the chain, and it's wrapping around the tire. With the chain hooked to an immovable object, such as a large tree, either the tractor moves or the chain breaks.
The tractor's tire works as a winch drum... VERY risky especially if not done properly.
The cheap HF winch idea will work fine... You can't hurt yourself because the cheap winch motor will stall out long before it exceeds the tensile strength of the cable.
It won't pull the tractor out straight-on, but if you "double the lines" a couple of times, forming a block-and-tackle, you will get plenty of pull and the winch will NEVER see more than its rated capacity. Your only limitation will the the length of cable. It's only 20'. After you double up the lines twice, you will only have 4'6" of pull.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
