you may also have a grease zerk for the clutch pilot bearing. if so, it is in the flywheel accessible at the bottom of the bellhousing thru the drain hole. on the crankshaft you will see two timing marks, and then a ways around there will be a single mark. line up the single mark to the timing pointer, the look up thru the drain hole at the fly wheel. if there is a zerk there, give it one or 2 pumps.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
