It is nearly impossible to find the puller that IHC provided the dealers. None of them around here have them. I called...
I built my own. I took a piece of heavy flat stock and drilled two holes 1 15/16" apart. Then I threaded short fine thread bolts into them for pulling the one half and I through bolted them to pull the inner part. (You can see both setups in the pics) Then on my final puller I welded a nut on to adapt to a LARGE slide hammer. This then banged them right out. (Thought, I did this on WD-6/MD injectors. Your's may not be exactly the same)
FYI - The pictured puller ended up being too small for the inner halves, but I don't have a picture of the bigger better puller.
This post was edited by sflem849 at 05:21:25 09/10/10 2 times.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
