Re: IH 240 Steering Issues
Posted by Janicholson on September 10, 2010 at 08:48:14 from (199.17.6.223):
In Reply to: IH 240 Steering Issues posted by KegStealer on September 10, 2010 at 06:48:52:
Assuming it is power assisted steering, the gear box oil level needs to be checked, as does the grease in the spindles. Jacking up the front prior to greasing will help get the grease where it belongs. A weak hydraulic system will also reduce steering power dramatically as will a failing or stuck priority valve (supplies Hydraulic fluid to the steering system)'
caseih.com search for parts has on line diagrams covering the steering It is under hydraulics for the power part, and steering for the gearbox. Jim
